8-Gravel
Dec 17, 2024 1:03 PM UTC
How to Generate NCL Code for the Upper and Lower Heads on Mill turn
HI,
I’m having trouble generating NCL code for PostProcessor on the Mill turn machine. The machine is equipped with milling and turning heads as well as two spindles. I need advice on how to properly generate NCL code for both the upper and lower heads of the machine.
If anyone has experience or tips, I’d greatly appreciate your help.
