Feb 3, 2017 10:43 AM UTC
How to output CUTTER command to the CL-file
I need to get the cutter diameter in the g-post. I see the CUTTER command in CL-file but it is commented like  $$-> CUTTER / 10.000000.
There is an Article CS212554, but I have no access to eSupport yet.
Document Details
Title How to output CUTTER command to the CL-file in Creo Parametric, without the comment marking ($$) in front of it
Description
  • Is there a setting that allows to output the cutter diameter to the *.ncl file as a command instead of a comment
  • How to get a real CUTTER command in the CL-file, i.e. without the comment marking ($$) in front of it?
  • The line $$-> CUTTER / 10.000000 follows the LOADTL command in CLDATA
Applies To
  • Creo Parametric all versions
  • Pro/MANUFACTURING
Cause
Where is the rest of the document?
This is a partial view of the Article. Click for full details on Article CS212554.
Resolution
Is anybody able tell me solution?
Feb 3, 2017 3:10 PM UTC
When G-Post processes the NCL file it converts all lines that start with $$ into REMARK commands.  So the $$ -> CUTTER / 10.00000,  etc.  gets changed to REMARK-> CUTTER / 10.00000.  You can capture the REMARK statements in the FIL file and identify the CUTTER data, then extract the cutter diameter.  It will be text so if you need it as a real number (scalar) you can convert it.  Here is some sample FIL code you can add to your existing FIL file that will do this:
CIMFIL/ON,REMARK
  REMTXT=TEXT/CLW        $$ GET THE REMARK TEXT STRING
  REMTXT=TEXT/OMIT,REMTXT,1      $$ REMOVE THE TRAILING BLANK SPACES
  CUTF=INDXF(REMTXT,(TEXT/'CUTTER / '))       $$ LOOK FOR THE "CUTTER / " STRING
  IF(CUTF .GT. 0)THEN
    NCH=CANF(REMTXT,1)       $$ GET THE NUMBER OF CHARACTERS LEFT IN THE STRING
    CDTXT=TEXT/RANGE,REMTXT,14,NCH       $$ PARSE OUT THE CUTTER DIAMETER VALUE
    CD=SCALF(CDTXT)        $$ CONVERT THE TEXT INTO A SCALAR
  ENDIF
CIMFIL/OFF
Fred Nemecek
CIMFIL/ON,REMARK
  IF(CUTF .GT. 0)THEN
  ENDIF
CIMFIL/OFF
Fred Nemecek
nazar_ko1-VisitorAuthor
Feb 3, 2017 4:53 PM UTC
Thank you. It works for me.
KenFarley
Feb 3, 2017 6:39 PM UTC
I had an inquiry back in 2013 that may be related. Here's a link:
Tool comments - can I extract them from the .ncl File
I kinda ended up answering my own question, but it wasn't a quick answer. I also included my code snippets if you're looking for them.
