Jul 15, 2021 11:26 AM UTC
HSM Rough speeds and feeds
Hi Folks!
When creating a HSM roughing NC sequence I've set the config option mfg_param_auto_copy_from_tool to 'all' but the finishing speed and feed data for the selected tool are written into the parameters, not the roughing ones.  If I create a Rough or Volume Rough sequence it imports the roughing speed and feed as I would expect.  Am I missing something or is this a giltch?
Thanks in anticipation,
Clive
