8-Gravel
Apr 25, 2014 11:39 AM UTC
Impeller machining _ vericut simulation including roughing tool path
- 0 replies
- 1790 views
- Translate All
Hurco VM10ui with Winmax 9 also supports programming with tool vectors, thus makes the NC program independent of any particular machine configuration. We are developing a post-processor in Creo 2 (G-Post) for generating a tool vector NC file rather than XYZAC format. Some case studies are planned; one example is impeller machining.
