7-Bedrock
Dec 19, 2011 8:08 AM UTC
Import solidworks files into Wildfire & Creo
I want to put the topic "How to import solidworksfiles into WF5 and Creo 1.0", because its a common problem.
As far as i know the Solidworks explorer is needed to be installed on the machine that will open the solidworksfile into WF and Creo.
But what version is supported or recomended from PTC and where can that be downloaded?
The solidwork explorer can usualy be downloaded from solidworks website but the only available explorer is 2012, which does not work properly to use for importing files.
Many Thanks
Lars
Dec 21, 2011 9:02 AM UTC
Hello!
You need to install Creo 1.0 M010, and also on the same computer SolidWorks Explorer 2012 (http://www.solidworks.com/sw/support/downloads.htm). At the same time, this integration works only for 32-bit version of Creo 1.0 (choose 32-bit platform in Creo 1.0 M010 install).
