Feb 24, 2026 3:26 AM UTC
imported solid tooling for manufacturing
how do you modify imported Kennametal boring bars to work in the simulation section in creo manufacturing. i dont know where to start on how to get tool to work
Feb 24, 2026 12:52 PM UTC
Hi
You must have a coordinate system named "Tip" at the exact point where you want the tool to follow the path.
Regards
Pushkar
KenFarley
Feb 24, 2026 3:38 PM UTC
Just a bit more info on that: The coordinate system must be oriented with Z+ along the spindle center, away from the tip of the tool.
Myself, I don't really use the solid tools. I suppose they would be helpful to avoid collisions, show actual depth of cut limitations, etc. but if I recall they made material removal simulation difficult? I can't remember.
Feb 25, 2026 2:27 AM UTC
Thanks for that ken, much appreciated
