Jan 26, 2010 6:22 PM UTC
Importing Points
I am trying to construct a curve based upon about 600 data points (2D) from a CMM. They are an a CSV file now. Any techniques of which anyone is aware? These are from the sphere center, so I'll just have to construct an offset curve to achieve the correct spline.
Feb 26, 2010 11:11 AM UTC
Hello Peter, you can copy & paste those point values into a text file & rename it to *.pts and goto offset coordinate (it will be in the same place from where you can create points). check in www.mcadcentral.com posted with similar topics Raghav
