Feb 1, 2010 10:37 PM UTC
Laser on/off between nested parts, how to stop it?
The output of NC_Sheetmetal is turning the laser off then right back on with nothing in between as it goes thru the sequences. How do you supress this behaviour so it stays on while moving thru the material?
    lococnc1-VisitorAuthor
    Feb 2, 2010 3:40 PM UTC
    The solution to my problem would appear to be in the post processor, specifically the FIL file.
    I have a pretty good understanding of how this file works, but it seems that you can only read and manipulate one command line at a time. What I need to do is look for this pattern in the output;
    PIERCE / OFF
    PIERCE / ON, CONST
    And ignore it.
    Logically it needs to look like this;
    If (CODE) == PIERCE / OFF
    AND next line ==
    PIERCE / ON, CONST
    Then Output (null)
    ELSE
    CIMFIL/ON,PIERCE
    T4TH=POSTF(7,4)
    CASE/T4TH
    WHEN/ICODEF(ON)
    INSERT/'M58$'
    WHEN/ICODEF(OFF)
    INSERT/'M59$'
    ENDCAS
    CIMFIL/OFF
    But I am not seeing how to do this with the capabilities of the FIL.
    Anyone can help?
    Feb 2, 2010 5:06 PM UTC
    Fred? 🙂
    Daniel Santos
    Suporte Aplicações CAM
    GE Oil & Gas
    T +55 11 4772-3565
    M +55 12 8173-6567
    F +55 11 4772-3775
    Rodovia de Acesso João de Góes, 2300
    Jandira - São Paulo - 06612-000 - Brasil
    Vetco Gray Óleo e Gás LTDA
    GE imagination at work
    Feb 2, 2010 5:56 PM UTC
    I'm "THIS CLOSE" to getting it to work right, here is the code I have so far;
    CIMFIL/ON,PIERCE
    T4TH=POSTF(7,4)
    CASE/T4TH
    WHEN/ICODEF(ON) $$ Always want to turn pierce on when told to
    INSERT/'M58$'
    WHEN/ICODEF(OFF)
    RSLT=POSTF(20)
    RSLT=POSTF(14) $$ Read the next command line to see if it turns pierce back on
    T5TH=POSTF(7,4)
    IF(T5TH.EQ.ICODEF(ON)) THEN
    INSERT/'DETECTED REPEAT$'
    ELSE
    RSLT=POSTF(21)
    INSERT/'NO REPEAT DETECTED$'
    $$INSERT/'M59$'
    ENDIF
    ENDCAS
    CIMFIL/OFF
    Problem now is it is killing my G00 after puttin in the "NO REPEAT DETECTED" part of the code...
