Sep 4, 2015 2:22 PM UTC
Local Mill
Na versao nova do CREO 3.0 M20 não consigo executar (local mill) após uma operação de (Windows mill ou Volume mill), mas é uma operação normal no CREO Parametric .
Como resolver este problema?
Na versao M50 ja esta resolvido.
Manufacturing‌
""In the new version of CREO 3.0 M20 I can not run (local mill) after an operation (Windows Volume mill or mill), but it is a normal operation in CREO Parametric.
How to solve this problem?
In the M50 version is already solved?
Sep 4, 2015 4:05 PM UTC
The volume milling sequence was redone in Creo 3.0.  I believe that the new volume sequence does not yet support local milling.  The workaround is to
Set “ENABLE_CLASSIC_NC_STEPS” to “YES”
This will allow you to use the new volume or the old volume sequence.  If you want to use local milling you will need to use the old volume sequence.
2-Explorer
Sep 10, 2015 5:15 PM UTC
Hello Jose,
did it work with classic sequences?
Here is the related article from our database: CS191225 : Unable to create Local Milling sequence with error message "Tool path could not be created; Please check the setup" in Creo Parametric 3.0
Gunter
