Oct 3, 2011 12:40 PM UTC
.mfg file no longer created for process models
We just upgraded from Widlfire 3 to Wildfire 5 and noticed something unusual about manufacturing models.
We have the Expert Machinist module, but we only use it to create process models (manufacturing planning).
(aka: Pro/Process for Manufacturing)
When the user saves such a model in Wildfire 5, it is no longer creating a .mfg file, as it did in Wildfire 3 and prior releases.
Yet, when opening the .asm file, Pro/E knows that it is a manuafcturing model, and opens it in the appropriate application (Process).
In short, it seems to be working properly, but I want to be sure I am not missing anything.
Gerry
Oct 3, 2011 1:34 PM UTC
Hi Gerry
I am not sure about Expert Machinist, but we try this with Molddesign:
Set allow_mfg_in_assem_mode to yes and open geometry in assembly mode.
Look at pictures on http://communities.ptc.com/groups/hezky-cesky/blog/2011/09/26/pr%C3%A1ce-na-molddesign-geometrii-bez-licence-molddesign
Regards
Radovan
