Apr 5, 2013 4:00 PM UTC
Mill Window stock clearance
I need some help with a 'Mill Window' roughing sequence. The tool is coming down tangent to the 'Stock' which is not safe. I would like the tool to plunge in the space around the material. Does anyone know how to set a boundary or an offset for that?
Thanks!
Apr 5, 2013 6:46 PM UTC
yes mill volumes are your only viable option for this and add approach surfaces to control the entry of your tool
Apr 5, 2013 4:09 PM UTC
could you throw up some screenshots?
Apr 5, 2013 4:20 PM UTC
Sorry Nick. I should have done that to start with.
Apr 5, 2013 5:23 PM UTC
No worries try this parameter.
Apr 5, 2013 7:34 PM UTC
Thanks for the help Gentlemen! I was able to get the path that I wanted with your help.
