Apr 15, 2015 12:18 PM UTC
Milling Extension license issue
Every time I open Creo Prismatic and want to use the Multisurface Milling Extension I have to go into the options menu, refresh the licenses, and select the correct license. Is there a way to make this persistent so I don't have to do this every time?
Apr 15, 2015 5:32 PM UTC
Brian,
you have to configure your Creo start command properly. This means you have to run reconfigure.exe and modify your startup command configuration.
Martin Hanak
Brian,
Martin Hanak
Mahesh_Sharma
22-Sapphire I
Apr 22, 2015 11:08 PM UTC
Brian,
Reconfigure Creo by executing reconfigure.exe from <Creo 2.0 Install dir>\parametric\bin > Next > Next > Customize > Command configuration > Edit > Move license from left to right > Ok > Ok > Install.
