8-Gravel
Sep 15, 2025 5:29 AM UTC
PC-DMIS showing some addition information that is not given in MBD Model
While using the Creo plugin within Hexagon’s PC-DMIS to load an MBD model, I’m seeing some additional dimensions in PC-DMIS that were not actually created in Creo MBD Model.
I’ve checked the annotations and combination states—everything looks clean in Creo. Is this a known issue with the plugin or PMI interpretation?
Any suggestions to control or filter what PC-DMIS reads from the Creo model would be helpful.
Emeritus
Sep 19, 2025 6:19 AM UTC
Hello @Karthik_1,
Thank you for using PTC Community.
Your question has not received a response so far.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
  1. Has anyone else experienced this when importing MBD models into PC-DMIS using the Creo plugin?
  2. Do you usually rely on combination states or annotation sets when importing models?
  3. Are there any settings or filters you typically adjust during import to control what gets read?
  4. Have you found any documentation or guides that explain how PC-DMIS interprets PMI from Creo?
Adding screenshots can also help. Overall this will enhance the likelihood of receiving valuable assistance from other Community members.
You might also find it useful to refer to this informative video on how to ask a good question.
I'm also responding to bring attention to your question. Hopefully, another community member will be able to assist you soon.
Best Regards,
Vivek N
Community Moderation Team.
