Mar 19, 2016 2:36 PM UTC
Play Path
We just switched to Creo 2 and I am struggling with play path. I used to be able to do play path, pick the file name and a it would open a dialog box that I could control the speed. It will still open the box if I go through the Process Manager. It will still run my CL file but I cannot control the speed so it goes real slow.What am I missing?
Thanks Bernie
    Mar 23, 2016 4:12 PM UTC
    oh i understand now you can also highlight just the sequences you want in the model tree and play those.
    Mar 21, 2016 12:22 PM UTC
    Bernie,
    I think that the cutting feed is too slow.  Maybe you made a mistake by defining the "cut data" for you tool and you entered 0.1 mm/min in stead of 0.1 mm/tooth.
    Then the feed is very slow and you can not accelerate it enough by the sliding bar.
    Jef
    Mar 23, 2016 2:09 PM UTC
    Instead of play path from a CL file move over to the model tree right click on the operation and click play path.  That will allow you to control your speed with the slider.
    pgf5451-VisitorAuthor
    Mar 23, 2016 3:28 PM UTC
    Thanks Nick, I have been doing that with no issues, but sometimes I will only do a CL file for a few sequences (set) and that is where the issue is. I used to be able to do it in earlier versions but I guess Creo2 doesn't do that anymore.
