Mar 12, 2014 7:03 PM UTC
Post Processor
We are currently running Wildfire 4 but will be upgrading to Cero pretty soon. I was asked to see if the processors will work with Creo. Can anyone let me know.
Thanks Bernie
Mar 13, 2014 12:19 PM UTC
Bernie,
Your post processors should work fine in Creo. I don't think there are any big changes other than revisions.
You could actually load Creo along side WF4 and test it to see if they will work because Creo will require a new license I think. Then delete WF4 after testing. Not sure what the licensing or legal aspect to that would be but I think as long as you delete WF4 after you are satisfied with how creo is working it would be OK but I am not an expert in that area.
Steve
pgf5451-VisitorAuthor
Mar 13, 2014 1:55 PM UTC
Thanks Steve, I am not sure about licenses etc. We have an IT dept that handles all of that stuff and I am sure they wouldn't do anything illegal. Thank you very much for the response. I will pass on the information to my boss and get the IT dept on the upgrades.
Bernie
Apr 21, 2014 9:18 AM UTC
One would assume you are using the G-Post that comes with Pro-engineer. We have not had any problems with going to Creo. We are also using Windows 7.
Apr 21, 2014 11:27 AM UTC
You should have no problems with the G-Post post processors when upgrading to Creo x.0. They should work just like they did in Wildfire 4.0.
