Mar 10, 2015 9:19 PM UTC
pprint problem
I use pprint tool_table to output my tool list in G_code program, only problem is my CNC screen is too small, there is big gap between two colomn, how can I delete those gap.
    KenFarley
    Mar 15, 2015 12:26 AM UTC
    I asked how to do something like this a while back and ended up working it out myself, with some other comments appearing later in time. Here's the link to the discussion and I have put code for post-processing into my responses...
    Tool comments - can I extract them from the .ncl File
    2-Explorer
    Mar 27, 2015 12:43 PM UTC
    Hello Linda,
    did Kenneth's link to the other thread resolve your issue?
    If yes, you may want to mark his post with the link as Correct Answer, to indicate to other users that the issue is solved.
    Gunter
    lzhao1-VisitorAuthor
    Mar 27, 2015 2:28 PM UTC
    I am not familiar with macro fil program, Anyway to change tool table format in pprint?
