Jan 21, 2010 4:24 PM UTC
Pro Manufacturing Tools
I have a situation where I have to usean end mill with a .015 corner chamfer. In pro man tool manager the only place I see to get a corner chamfer is with a chamfer tool. The problem is with the rigid tool use in pro man they do not allow you to use a chamfer mill to side mill. Am I missing something, what can I do to get a milling cutter with a corner chamfer that will side mill am I missing something?
Jan 21, 2010 7:01 PM UTC
Steve,
I profile milling and volume milling it will only give you the option of
picking a bullmill and specify the chamfer as a rad (I know it is cheating).
You could use your own solid model and have the chamfer modeled in.
However in trajectory milling you can pick the countersink as your milling
tool.
Hope this helps
Tony
