Jan 9, 2025 8:44 PM UTC
Problem mouse in EMX
I have a problem with the mouse in the mould base definition window, when I place the mouse over a plate it does not select to select it I have to move it either to the side or higher up,
has anyone ever had this problem? if so how did you solve it?
i have also tried with older versions but always the same problem.
Apr 7, 2025 12:21 PM UTC
Good morning to all
Problem solved.... I had to uninstall graphics card drivers re-install new drivers...the strange thing it didn't do it on all versions, anyway solved.
Jan 10, 2025 7:57 AM UTC
Maybe @tschneyer can comment your problem.
Jan 10, 2025 9:55 AM UTC
Hello gcambiaghi,
maybe it is a screen resolution problem. Can you tell me your screen resolution and your scaling factor (175%)?
Then we can try to reproduce and fix it.
Kind Regards,
Thomas
gcambiaghi14-AlexandriteAuthorAnswer
Good morning to all
