Jun 25, 2013 10:50 AM UTC
Problem with Creo Progressive Die 7.0 M010
Hi all,
I am facing an odd problem with Creo PDX,
after defining Bend, Piercr or Form locations on the Strip, material does not get cut on the Strip.
pls see the attached image : scree.JPG
also the sheeetmetal component model.
Pls Help..!!
Shashank
Apr 18, 2014 5:22 PM UTC
How do you solve this problem with Creo Progressive Die. I have the same problem.
PLEASE
