Nov 11, 2022 9:52 AM UTC
Problem with G41 cutter compensation in a volume milling
On my part, I use the volume milling function to create a slot diameter 4.2mm at the bottom of a side pocket in my part. For that I use an end mill diameter 4 and it works well.
But when I try to use the cutter compensation (G41), nothing changes in the Gcode file.
I have other sequences such as profile milling and the G41 is correctly converted into the GCode.
It never works with volume milling?
Does someone have an idea?
Thanks in advance
KenFarley
KenFarleyAnswer
Nov 11, 2022 12:30 PM UTC
From what I can find it seems that the volume milling does not use cutter compensation. The discussions I've seen seem to indicated that people use volume milling to rough out the pocket, then a second toolpath to finish the walls with cutter compensation. For example, see this discussion:
Volume Cutter Comp Discussion
KenFarley
KenFarley21-Topaz IIAnswer
RJ_FR12-AmethystAuthor
Nov 12, 2022 2:22 PM UTC
Ok, thanks for the answer.
