Oct 19, 2015 8:57 AM UTC
ptc creo 3 - ramp angle
dear friends;
we are using creo 3 for cam programming , in roughing program although I mentioned ramp angle as 5 degree /less than 90 , cutter directly plunging on the material with out taking any ramp, does any one know the reason ? I am using volume and window .
RaphMORINAnswer
Oct 19, 2015 3:29 PM UTC
Hello, if you're using the new volume milling sequence you must specify a ramp entry. With the old volume sequence (Creo 2 and before) we didn't have to specify this, as soon as we were defining a ramp angle, the approach movement was a ramp.
Oct 19, 2015 1:56 PM UTC
if you use this site file and then change the ramp angle from 90 to 3 degrees it should work. If you want a helical entry change the "helical_diameter" to whatever diameter you want. If you want ramp then change that to "0"
RaphMORIN16-PearlAnswer
2-Explorer
Nov 2, 2015 5:49 PM UTC
Hello Sreemesh,
did you try the suggestions? Did they help?
Please consider marking posts as correct, if they help you solving issues (only one allowed per thread, so you have to decide, if multiple posts are helpful)
Gunter
Nov 23, 2015 10:47 PM UTC
it is not solved
Dec 17, 2016 9:48 AM UTC
This is a correct solution thank you.
Jan 24, 2017 11:21 AM UTC
refer the above image and change it the tool will move according to the entry which you are going to select
