Jul 14, 2021 2:39 PM UTC
Return pin in EMX mouldbase
Requesting EMX team to separate "Return pin" from ejector pin category.  The issue is during cleaning up ejector pins using command " delete all ejector pins" , this return pins will also get deleted and need to reassign all the references related to it. kindly check.
tschneyerAnswer
Aug 4, 2025 7:16 AM UTC
Hello Abhinand,
we will consider this. Return pins will not be deleted anymore in case of "Delete all ejector pins" beginning with Creo 10.0.11.0, Creo 11.0.7.0 and Creo 12.4.2.0
Kind Regards
Thomas
tschneyer12-AmethystAnswer
Hello Abhinand,
Kind Regards
Thomas
