Jan 12, 2021 3:00 PM UTC
seeking milling sequence advice- Creo Manufacturing but somewhat generic
I've devised a milling sequence which will make my part, but I would like what I've done criticized for my choice, and sequence, of methods. I would post an image of the part and then list sequence ie. mill window, face, rough, profile, finish and include tool choice.
Cycle time is not really an issue, but I guess I worry that what I'm doing may not be best.
CNC Mill is a Sherline 2000 running under LinuxCNC.  I did the Post with GPOST and it has worked fine with other parts.
If this is reasonable to ask, how should I post my topic?
Jan 14, 2021 3:54 PM UTC
Can you save a backup of your manufacturing files to a folder and then zip it and upload?
Jan 14, 2021 3:55 PM UTC
sure.  later today.   and thank you for your reply.
Jan 20, 2021 8:44 PM UTC
Manufacturing Files,  Does this mean the model, the workpiece, and the Manufacturing.asm files,such that you can load everything?  I ask not from concern about showing the part, but because this seems like a lot for you to look at.
Let me know how to give you what you are asking for if it isn't all of the above,
and thank you for your very kind offer.
john
