Oct 17, 2025 11:54 PM UTC
Setup Sheet Creation Tool GPOST
This is handy.  I modified it today to use with G-Post (I have been using FORTRAN posts for 25+ years, and just made the switch this year).  This will build a setup sheet from your apt source file.  It should be easy enough to understand and tweak for your own needs.  I find it very handy for creating run books.
I compiled using FreeBasic but it's easy to convert to your language of choice.
You can create a .bat file and attach it to one of your Cimpro buttons:
echo off
cd %2
@C:\anc\camsys\SetupSheetHelper.exe %1
Main Program:
'SetupSheetHelper Main Program
'Bryan Felsher                        01-03-10
'Modified 10-17-2025 BCF for AUSTIN NC G-POST
Dim Shared As Integer i=0,n=0,iTLNUM,SEQNUM=0,iPRNUM
Dim Shared As Integer FILTYP = 0, FREAD = 0
Dim Shared As String sLNIN, sLNIN2, sNLINE,sTIME, sINFNM, sOFLNM,sLNOUT
Dim Shared As String sTOOL(150)
sLNIN=""
sNLINE=""
sLNIN2=""
Declare Sub FILOPN
Declare Sub SETTML
Declare Sub HEADER
Declare Sub TLLIST
Declare Sub NCOUT
Declare Function APTMAJ(LINEIN As String) As String
Screen 10
'SETTML
FILOPN
If InStr(UCase(sINFNM),".APT") < 1 Then
   Print _
   "ERROR: INVALID FILE TYPE. MUST BE .APT OR .APTSOURCE FILE TYPE."
   Beep:Sleep:End
EndIf
'BUILD TOOL LIST
iTLNUM = 0
Do While Not Eof(1)
   Line Input #1, sLNIN
   sLNIN=UCase(sLNIN)
   If APTMAJ(sLNIN) = "PPRI" Then
      Line Input #1, sLNIN2 'READ NEXT LINE
      If Instr(sLNIN2,"LOADTL") >0 Then
         iTLNUM += 1
         sTOOL(iTLNUM) = LTrim(sLNIN,"PPRINT")
         sTOOL(iTLNUM) = LTrim(sTOOL(iTLNUM),"/")
         sTOOL(iTLNUM) = Trim(sTOOL(iTLNUM))
      EndIf
   EndIf
Loop
Reset
FILOPN
HEADER
Do While Not Eof(1)
   sLNIN=UCase(sLNIN)
   Select Case APTMAJ(sLNIN)
      Case "PART"
         iPRNUM = Val(LTrim(sLNIN,"PARTNO"))
         sLNOUT = "PROGRAM NUMBER: " & Str(iPRNUM)
         NCOUT
         Print #3, " "
      Case "FROM"
            TLLIST
            FREAD = 1
      Case "DISP", "PPRI"
         If APTMAJ(sLNIN) = "DISP" Then sLNOUT = LTrim(sLNIN,"DISPLY")
         If APTMAJ(sLNIN) = "PPRI" Then sLNOUT = LTrim(sLNIN,"PPRINT")
         sLNOUT = LTrim(sLNOUT, "/")
'Remove CATIA comment lines
         If InStr(sLNOUT,"OPERATION NAME") Then sLNOUT = ""
         If SLNOUT = _
            "********************************************" _
            Then sLNOUT = ""
'Remove tool description lines, handled later.
         For i = 1 To iTLNUM Step 1
            If Instr(sLNOUT, sTOOL(i)) > 0 Then
               sLNOUT = ""
            End If
         Next
'Check for sequence of operations notes
         If FREAD = 1 Then  'Handle comments after FROM read
            If InStr(sLNOUT,"SEQ") Then
               SEQNUM+=1
               Print #3, sLNOUT
               sLNOUT = ""
               Print #3, STOOL(SEQNUM)
            End If
         End If
         NCOUT
   End Select
Loop
Print #3, "************** END OF PROGRAM **************"
Reset
Beep
Dim As String MAJOR
MAJOR = Left(LINEIN,4)
Return MAJOR
End Function
Sub FILOPN
ChDir ExePath
sINFNM = Command(1)
sOFLNM = Left(sINFNM,(InStrRev(sINFNM, ".")-1)) & "_SetupSheet.txt"
Dim choice As String
If Len(sINFNM)=0 Then
   Print "Missing parameter : No Input file!"
Input "Select file for input? [Y,N] ";choice
choice=LCase(choice)
If choice = Chr(121) Then
Input "Enter Filename for Input: ";sINFNM
sOFLNM = Left(sINFNM,(InStrRev(sINFNM, ".")-1))_
            & "_RunTime.log"
Else
End
End If
If Open (sINFNM For Input As #1) <> 0 Then
  Print "Error: can't open Input File!"
  Sleep:End
Else
If Open (sOFLNM For Output As #3) <> 0 Then
  Print "Error: can't open Output File!"
  Close #1
  Close #3
  End
end If
End If
Else
  End
Else
  Close #1
  Close #3
  End
end If
End If
End If
Return
End Sub
Sub SETTML
Dim As String TimeLimit = "12-22-2010"
Print "Today's date is: ";Date;_
   ". You have until ";TimeLimit;" to try this software."
Print
Print "Press any key to continue."
Sleep:GetKey
If Date > TimeLimit Then
Print "Time limit ";TimeLimit;" has expired."
Sleep:End
EndIf
Cls
End Sub
Sub HEADER
Print #3, "******************************************"
Print #3, "True Precision CNC Programming Services"
Print #3, "Ph: 310-750-6761"
   Print #3, "Email: trueprecisioncnc@outlook.com"
Print #3, "Website: www.trueprecisioncnc.com"
Print #3, " "
Print #3, "Setup Sheet Comments extracted from : "
   Print #3, sINFNM
Print #3, " "
Return
End Sub
Sub TLLIST
   Print #3, ""
Print #3, "*****************TOOL LIST******************"
Print #3, sTOOL(i)
Next
   Print #3, "********************************************"
   Print #3, ""
   Print #3, "***********SEQUENCE OF OPERATIONS***********"
   Print #3, ""
i=0
   Return
End Sub
Sub NCOUT
   If sLNOUT <> "" Then
      Print #3, Trim(sLNOUT)
      sLNOUT = ""
      sLNIN = ""
      sLNIN2 = ""
   EndIf
   Return
End Sub
KenFarley
KenFarleyAnswer
Oct 30, 2025 2:26 PM UTC
In the past, people have asked how to output a list of tools being used by a particular program, and include that list in the program itself. I do this myself, so that when someone in the future (often me) needs to run the program again, all the information they need is in one place.
To do this I needed to do some extensive FIL programming, detailed in one of the posts about it, here:
https://community.ptc.com/t5/Manufacturing-CAM/Getting-tools-to-Post-Out-to-my-programs/m-p/40539
An alternative to making setup sheets, I guess.
KenFarley
KenFarley21-Topaz IIAnswer
Catalina
Community Manager
Nov 4, 2025 12:09 PM UTC
Hi @BF_14259101,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
