Jul 9, 2018 2:46 PM UTC
Show NC Sequence CSYS in Model Tree
Is there a parameter that can be added as a column in the model tree that will show each NC Sequence coordinate system used?
KenFarley
Jul 9, 2018 5:06 PM UTC
I don't know of any such column or whatnot to show which CSYS is used by a particular NC Sequence. I'd hoped that it might highlight the pertinent CSYS when I picked the NC Sequence from the model tree, but no such luck.
Guess the only way to be absolutely sure is the tedious Edit Definition nightmare.
Jan 29, 2019 2:40 PM UTC
The Process Manager will show which CSYS each sequence uses. Just enable the "Orientation" from the "Mfg Setup Items".
