Mar 5, 2021 2:34 AM UTC
sketch error
I am using Creo Parametric 5.0 5.0.4.0
I'm trying to remove material ina rotating sketch.
Applies at 4 microns, but not at 3 microns.
I don't know the cause.
Is there a way to define it below 3 microns?
    Mar 5, 2021 7:48 AM UTC
    I guess it is accuracy problem. Set absolute accuracy and lower its value.
    Mar 8, 2021 1:12 AM UTC
    Hi, @Martin Hanák
    Thank you for your answer !
    I try to set abusolute accuracy.  🙂
