Feb 4, 2021 7:22 AM UTC
smooth machining in creo ??
dear expert is there any option in creo machining to get smooth machining??
regards
Fisa
Apr 12, 2021 7:40 AM UTC
how your question should be understood - are you referring to the surface roughness or smoothes of the process of program generation in creo?
asifcad15-MoonstoneAuthor
May 26, 2021 5:13 AM UTC
my question is about nontangential surface connection. Cuttline milling sequence stopped for a millisecond on a nontangential surface connection. due to it, there is a line mark on the machining surface. also, my programe cutting feed is 3000mm/m but on the connection point, the feed suddenly changes to 200 or 300 mm/m. I hope you can understand. already post about this issue but still find no answer please check it
https://community.ptc.com/t5/Manufacturing-CAM/strange-gouges-showing/m-p/702206#M4709
regards
Fisa
