Oct 26, 2017 1:33 PM UTC
Strange icons in Sketcher
Apologies if this is a duplicate email, I am not seeing the previous post
  We are seeing strangeness in sketcher (Creo 4.0 M020). It starts with the lines in Sketcher beinging to get larger and then icon representations changing. We have also seen line thickening in drawings. See below froma  machine that is seeing issues in sketcher.
  Seen on a range of Dell machines with low end nvidia graphics cards.
  We have tried fixing the line width in Sketcher, but no effect.
   Many Thanks for any hints
Oct 26, 2017 2:08 PM UTC
can you see the same problem in Creo 3.0 ? If Creo 3.0 is OK, then try updating graphic card driver on one machine.
cadcam1-VisitorAuthor
Oct 26, 2017 6:19 PM UTC
We haven't seen a similar issue in Creo 3.0, but then there are no/different icons in sketcher.
 It is difficult to upgrade one machine as there are 250+ machines central served. At present we can't reproduce the 'fault' / 'special feature' to order so it would be difficult to see if there are any changes re graphics driver. However I will check with the IT department but I think we are seeing the problem across a number of different drivers as they are required for the different cards.
 Regards
Mahesh_Sharma
22-Sapphire I
Oct 26, 2017 2:12 PM UTC
Or share the file. You may strip some of the feature and share this file. We can check this.
Oct 26, 2017 6:20 PM UTC
Not sure it is part specific, but next time I have a part exhibiting the effect I will post it.
  Regards
Oct 26, 2017 6:31 PM UTC
Update, In the same session opening the sketcher in various parts & features seem to generate the issue. Thus fairly sure it is not part dependent.
  Regards
6-Contributor
Oct 26, 2017 8:19 PM UTC
Try to change screen resolution.
Oct 26, 2017 8:51 PM UTC
Not on the Creo 4 machine until tomorrow now, but it is being seen in at least two different screen resolutions ( on different machines). Will investigate further tomorrow
