To Create an Auxiliary NC Sequence in Creo 7.0
Hi
this is the online Creo 7.0 help link on how To Create an Auxiliary NC Sequence:
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/index.html#page/manufacturing%2Fnc%2Fto_create_an_auxiliary_nc_sequence.html%23wwconnect_header
But I can't find it in Creo 7.0 . In Creo  6.0 it's the same.
I have the Creo 2.0 installed and there I can find it.
Any idea how To Create an Auxiliary NC Sequence with Creo 7.0 ?
Sorry,
That was supposed to be enable_classic_nc_steps yes
Regards
Pushkar Khanna
@mdenicola wrote:
Hi
please ask PTC Support. Maybe you have to set some config.pro option...
Use the hidden config option enable_classic_cutline yes,
Then you will find aux nc sequence
regrads
Pushkar Khanna
Sorry,
Regards
Pushkar Khanna
mdenicola14-AlexandriteAuthor
Hi
yes, with the config option:
it's working
Thanks !
