8-Gravel
Jul 9, 2019 6:30 PM UTC
Tool center point control and Dynamic work offset
Most of the CNC builders offer option liked the one in the title. Does anybody know how to activate/ control them using GPost. Or how to capture things when you need 3+2 machining or 5 axis machining?
Apr 24, 2021 3:28 AM UTC
 First of all the TCPC is a control option for true 5 axis machining.  Find Jose Cornodo will tell you all about it. And dynamic is also a controller that works with G82 only and other for G54.4 on Fanuc I31B.
After you got all of this working come back i tell you more ...
