Feb 20, 2021 2:52 AM UTC
tool list
Is it possible to save my list of tools in pdf format or print?
KenFarley
Feb 20, 2021 7:02 PM UTC
I'm not sure if anyone else has an idea about this, but in Creo 4.0 there isn't any printing functionality provided in the "Tools Setup" dialog. What you could do is bring up a text representation of the tools by using
View -> All Tools
You could select all the text in that window, copy and paste it into a new notepad file or some such, and then print it. What I don't like about this particular method is the list doesn't provide the tool numbers. Makes it kind of hard to use for doing tool setups.
Feb 22, 2021 11:28 PM UTC
thank you for your support ken, i gonna use it.
and i am using creo 7.0, and  i found a posible other solution, but i don't know how to use it.
it is located on:
applications -> process documentation  when you press it, a box shows up, with some options about the process and tools.
do you know something about it?
Feb 23, 2021 8:07 PM UTC
You can create a drawing of your manufacturing assembly, then insert a table with repeat regions of the manufacturing variables that you would like to document. In Creo 7, in drawing, on the table tab, use Table->quick tables to find some examples. Those are pretty basic, though. I've included the two I use as an example.
Feb 23, 2021 8:46 PM UTC
thank you bmuller. it will be very helpful.
Jul 14, 2021 8:21 AM UTC
Hello
contact me if you want my file tool list format
ali.araar@georgfischer.com
tool list auto PDF
