Unusable code posted from CL
- 5 replies
- 857 views
- Translate All
Im running in Creo 10.0.3.0 and am having an issue getting usable code to post. My manufacturing assembly is generating toolpaths and everything simulates correctly. I am able to generate and save a CL file, no problem.
When I go to 'Post a CL File', I choose the CL that was made, and select uncx01.p11 from the PP menu. We are using Haas VF4 mills and although this post is labeled for VF8 mills, we have had other engineers post code without issue in the past. The problem is nobody recalls what(if any) additional setup needed to be done.
After I choose my post, I get a command prompt window displaying "NCL record= 200 ENTER PROGRAM NUMBER"
I enter a short number like 0001 and I get the following log file:
Log File
NC-GPOST Mill, Version 6.8 P-20.0, Copyright(c) 2020
Build number=0279
Date=08-19-2025 Time=09:54:02
Input File=op010_FILE_mill.ncl.1
Option File=uncx01.p11
Filter File=uncx01.f11
*** Tape length 12.00 Cycle time 1.48 Warnings 0 ***
Date=08-19-2025 Time=09:54:06
If I navigate to the files that were generated, I see op010_FILE_mill.lst and op010_FILE_mill.mbx. The files I have seen that were made previously are all .tap files, and the .mbx shows that there should have been a op010_FILE_mill.tap generated(the message log in Creo also says a .tap file was made successfully) but it is nowhere to be found.
The op010_FILE_mill.lst file contains code, but it doesnt read like any Haas Gcode Ive ever seen. I have it attached to this post.
Any help would be greatly appreciated!
