8-Gravel
Feb 21, 2013 6:44 PM UTC
Using Pro NC in Creo 2???
Does anyone know how to get Creo 2 Pro NC module up and running? The old way was tools/Floating_Modules can't seem to figure it out in Creo 2. Also is there any enhancements to the tool anyone knows about?
Jeff
    Feb 21, 2013 6:52 PM UTC
    Jeff,
    they have changed how it works. Now you have to go to the file pulldown then the licensing near the bottom then you can add floating modulesby refreshing the list.
    I will work on showing something for you to load them in the setup so you don't have to do it each time you start Pro E.
    Steve
    Feb 21, 2013 7:06 PM UTC
    Jeff,
    Sorry missed a step shoulde be file pull down then options then licenseing then refresh the list.
    jeuclide8-GravelAuthor
    8-Gravel
    Feb 21, 2013 7:56 PM UTC
    You did it again!!! Thanks Steve!! I will skunk you one of these days!!!
    Jeff
