Feb 17, 2011 9:35 AM UTC
Volume disappears ?
Hey guys..
I have a strange problem.
Sometimes when creating a mill volume path , it can´t be mill because the mill volume suddently disappears.
I´ve had this problem a couple of times , but not every time.
I make the seq , choose the volume (which appears in solid) , and everything seems okay. But when i try to play the path , the volume is gone.
You can still see it in the modeltree , but not select it on the model..
In this case i´ve fix it with a mill vindow , but still real frustrated..
Have anyone had similar problems ?
Feb 17, 2011 3:20 PM UTC
You had me confused for a few minutes
i had to go into the seq setup and add the top surface as the "top surface"
Feb 17, 2011 1:15 PM UTC
Yes I have had this problem what i found is that if you go to
VIEW
VISABILITY
UNBLANK
OK
it will unblank your volumes
Feb 17, 2011 1:44 PM UTC
Still the same problem..
I can see the volume , but not select it 😞
Try make a volume path on my attached part , and you will se the problem...
Feb 19, 2011 10:05 PM UTC
Hey Jesper,
This is just one more of Pro/NC nasty bugs... I know it since WF2.0
They are too busy making Pro/NC far better than the competition... :sarcasm:
Daniel
