Jun 26, 2015 12:46 PM UTC
What's new in DFMPro 4.0 for Creo Parametric!
New DFMPro 4.0 comes with added support Creo Parametric 3.0 along with support for modules like tubing, sand casting and investment casting. Wall thickness is the critical element in achieving defect-free parts in sand casting and investment casting. The new release of DFMPro helps to define the wall thickness requirements as rules which can be easily specified for individual as well as a set of components.
DFMPro is a powerful CAD integrated Design for Manufacturing & Assembly solution, which facilitates upstream manufacturability validation and identification of areas of a design that are difficult, expensive or impossible to manufacture. With the new version of DFMPro 4.0, Creo Parametric users can have much greater flexibility to design products for multiple processes, including additive manufacturing, tubing and sand casting and significantly reduce engineering change orders (ECOs) by getting their designs right the first time.
Seamlessly integrated within Creo, DFMPro allows you to
  • Eliminate rework due to manufacturing and assembly errors downstream
  • Run DFM checks at the click of button within CREO and Pro/ENGINEER, plus edit and update the design without leaving the CAD environment.
  • Use DFMPro for common manufacturing processes like plastic injection molding, sheet metal, machining (Turning, milling & drilling) and assembly operations
Discover how DFMPro 4.0 for Creo Parametric can help design BETTER products in Less TIME and COST!
