May 28, 2015 12:02 PM UTC
Who out there is thread milling in Creo 2.0?
I'm in the process of developing a thread milling process but I am not getting the correct tool path.  I need a single pass tool path but I'm not able to find the right parameter combination to get single pass. I using a solid tool defined in Creo to simulate a multi-tooth cutter.
ejwAnswer
May 28, 2015 12:30 PM UTC
Rick
I think the thread milling tool is the problem. In PTC's infinite wisdom flutes are not flutes for a thread milling tool. Flutes are the number of thread profiles on the tool. Measure the lenght of profiles and divide by the pitch of the thread. Round to a whole number and put this in the "number of flutes" for the tool. This should change the number of turns the tool makes.
Ed
ejw1-VisitorAnswer
Rick
Ed
rcordova10-MarbleAuthor
May 28, 2015 1:45 PM UTC
Ed, you nailed it!  Thank you for your quick response.
