3-Newcomer
June 15, 2023
Work offset does not appear in nc code
  • June 15, 2023
  • 3 replies
  • 1747 views
Hello all I am trying to use the manufacturing side of creo to make a couple basic parts and it seems to be not posting the G90 or G54 lines in the nc code, below is a screenshot of the beginning of the program. I've used a few other CAM systems but this is the first time I've tried using creo for machine toolpaths, so I might have something not set correctly. Below is the post I tried using, it said it was for a HAAS VF8. Does anyone know what I need to change so these 2 lines of code will be in the nc code output?
Best answer by JonathanCook
Add G0 to the start program of the program.  See video.
You have to set the parameter named FIXT_OFFSET_REG.
This video shows where the parameter is located.
1badc203-NewcomerAuthor
3-Newcomer
June 16, 2023
Thanks Jonathon, that seemed to get it!
