11-Garnet
2 conditions
Hi there I need some help to simplify the program that I made in Mathcad Prime  3.1 . I am using lookup  to get the required profile. But there are 2 conditions that I need to satisfy. If in condition 1 satisfied  the pre selected profiles. Condition two also should pass the utilization. If condition two did not pass how this will pre select up to a higher value to satisfy both conditions.  I attached the file for your reference.
LucMeekesAnswer
23-Emerald V
I have experience that it does not work most of the time.
What you then should do is iterate inside the program for each of the input values.
So in essence:
r <- ORIGIN
if IsArray(x)
   for i el ORIGIN...last(x)
     Rr <- Select(xi,yi,data)
     r <- r+1
return R
will give you a nested array with the results.
Assumption is that y is as long as x. If not, your program becomes more complex.
Many of us cannot open Prime 3.1 files.  Can you post a PDF of the whole document and/or better explain what you're trying to do.
23-Emerald V
Your Prime file doesn't run for me. The Excel file is missing and a number of variables are undefined (due thereto?).
I see no way to use the lookup functions of Prime to do what you need. It can be done using a program, see my example below in the program "Select", and two examples of its use:
This was done in Mathcad 11, (my Prime Express doesn't allow programming),
but you should be able to recreate the Select function in Prime.
ldante11-GarnetAuthor
11-Garnet
HI Luc,
I tried to adopt your program  and this is the result I am getting . How can I get the optimum value?
Thank you
23-Emerald V
Lex,
What is the criterion for the optimum solution?
11-Garnet
Hi.
Here is the attached excel file and pdf file format.
Step 1: I used lookup "It" to get the pre-selected profile by deflection criteria,
Step 2: I used lookup "eq" to select the profile base on step 1
Step 3: I used look up "eq" to select section modulus from the excel data.
Step 4:  some condition the design moment will exceed from the allowable.
Step 5: I need to compare step 1 and 4 if both will satisfy the design criteria otherwise step 1 will select another data to satisfy step 4.
I don't know if this will be clear to you now.
Regards
