regcurry
2 questions on Fourier transforms in Mathcad 15
1.  Unless I am missing something, there is a inconsistency in the time conventions of the fft and the symbolic Fourier transform function, fourier.  See attached
2.  Has anyone developed a Filon technique Fourier transform in Mathcad 15?
Reg
-MFra-
-MFra-Answer
Hi Reg Curry,
there is a whole collection of mathcad inconsistencies, to which we can add this on the Fourier transform. It follows a comparison with the Wolfram results:
-MFra-
-MFra-21-Topaz IIAnswer
Hi Reg Curry,
regcurry
regcurry16-PearlAuthor
F.M.--
Thanks much.
By the way, how did you input the programming version of fourier built-in function with alpha >0  ??  When I try to add a programming line the symbolic arrow appears only after the alpha >0, and not for the whole expression.  There is clearly a syntax input I don't understand for using constraints with the built-in functions in programming mode.
Thanks again.
Reg
regcurry
In summary, with F.M. help above, attached is my summary of inconsistencies between symbolic integral Fourier Transforms and the built-in Symbolic Fourier Transforms.
