3D PLOT with units by PRIME7
Hello everyone,
I attached work sheet with PRIME7.
I can not use any units in 3D plot.
And I canceled the units of valuables, but also I can not have any plots.
Is this correct ?
ttokoro
ttokoroAnswer
Auto labeling changed my result. Use new attached sheet.
t.t.
ttokoro
3D PLOT without units by PRIME7.
t.t.
ssato15-MoonstoneAuthor
Hello ttokoro san,
I have following message, and can not plot.
No data found. Try changing the axis range or the axis formula.
ttokoro
ttokoro21-Topaz IAnswer
t.t.
ttokoro san
Thank you for your response.
