3D Plots and Volume
Hello to all,
I am starting to explore the world of 3D plots in MathCAD.
I am relatively comfortable with 2D xy plots and creating graphs and evaluating them etc by using xy data and applying a polynomial function to extrapolate a curve from said plots. I am also comfortable with evaluating the area under the curve produced in this way with various integrals.
I am not looking at how challenging it may be to add the 3rd dimension i.e. if I have a variety of xyz data plots, how hard is it to plot them into a 3D plot and to bound a volume within them? Further how challenging is it to evaluate the volume within i.e. to find the centroid of the volume etc?
Andy.
See please one example with Mathcad Calculation Cerver here
http://twt.mpei.ac.ru/MCS/Worksheets/Regress-z-x-y.xmcd
We have data as point on the syrface an needet value as cross-hair on the 3D plot
If it is what you need I can send the sheet!
But better is the using not a surface but a set of curves
http://twt.mpei.ac.ru/MCS/Worksheets/Interp-f-x-y.xmcd
awibroe1-VisitorAuthor
Hi Valery,
Impressive! I think what I am after is being able to plot a variety of scatter points where I have a series of x, y and z data similar to your website.
I am then looking to see how I can 'connect' these to make a surface around these points and then to evaluate the space within the surface. Does that make sense?
I have been experimenting with simple shapes i.e. a cube. Where I have 8 points of a cube defined by their respective x,y,z points. When I try to plot these I only seem to be able to add z axis data not x or y data?
Andy.
