Jul 2, 2010 10:47 PM UTC
3D Plots in MathCAD 14
I'm new to these forums and I just had a quick question. When I set up a two variable function and try to plot it, MathCAD recognizes the function and seems to plot it successfully but it doesn't display. I can, however, see contour plots of the same function. Vector field, 3D scatter plot and 3D bar graphs don't display either. I'm kind of thinking it's a plugin problem or something. Any ideas?
Thanks.
Jul 2, 2010 11:05 PM UTC
Could you post the worksheet please. Without the worksheet there is no way to know what the problem is.
Jul 2, 2010 11:08 PM UTC
Yeah, no problem. I'm thinking it's a problem on my end but I guess I never know.
Jul 3, 2010 12:03 AM UTC
Exactly 🙂 There are known problems with 3D plots displaying, but step one is to be sure they should display, and it's not just a syntax error. The bad news is that I see both plots, and it's not a syntax error 😞
Which version of Mathcad are you running (including service releases), and which OS? There are known problems with Windows 7, especially 64 bit.
One fix that has worked for some, but not all, is to right click and uncheck "Border".
Jul 3, 2010 7:10 AM UTC
Stephen,
You want everything in one go ! Plotting is quite an expertise,
but the maths that permit plotting is the core of a project.
Visit the "Usage", download all my work sheets, that will
help you start . The attached work sheet is under collection,
already to a fair %. There is a huge amount of the Mathcad
ways of doing, all applied and by examples.
jmG
________________________________________________
Another stupidity from this web design:
I reply, attach the work sheet, a new work sheet
but can't put the tags I want or any tag at all !
Let's assume the tag is "3DtoolBox[jmG]" .
Why should I be refused ?
Jul 3, 2010 1:35 PM UTC
What kind of democratic argument ?
Is it because of the skin color or else ?
Is it because I'm not WASP
WASP = "White Anglo Saxon Protestant "
The tags apply to the entire thread, so only the originator can choose them.
If you want to post a worksheet and tag it then go to the documents tab on one of the Mathcad Community pages and post it there.
Since you haven't set an avatar or uploaded a photo of yourself to your homepage nobody has any idea whether you are a WASP or a Martian
innocent.gifor Alien.gif???
Jul 3, 2010 3:18 PM UTC
nobody has any idea whether "you" are a WASP or a Martian< [Richard]
Thanks Richard [Doctor Who]
Jean
Jul 8, 2010 10:07 PM UTC
This problem has come up a number of times and darn, Mathcad 15 still has the problem.
However, a work around that seems to work in vista and Windows 7 is to change 32 bit to 16 bit. Under windows 7 you can go to desktop(right click>>Screen Resolution>>advanced settings>>List All Modes>>High Color (16 bit).
Then save settings and select keep settings.
Since Windows Vista uses an older version of the same engine that drives Windows 7, the options maybe elsewhere but are similar.
Jul 8, 2010 11:45 PM UTC
I read that somewhere else in these forums and tried it on my machine and it worked perfectly. It just seems weird that MathCAD can't display 3D graphs in 32 bit color.
Jul 9, 2010 3:07 AM UTC
Stephen,
"It just seems weird that MathCAD can't display 3D graphs in 32 bit color."
Mathcad dispays nothing, Windows does. Unless you have a specific software
for 32 or + bits, all stand alone by itself [not windows], i.e: a software that takes
your image from source and displays on its own system, you won't get the same
capability in Windows, because colors are coded 24 bits, the extra 8 are for *PNG..
The other point is about the actual idiosincrazy in screen dispaly . Any screen
that fits Windows has resolution 96 PPI [Pixel Per Inch]. The human eye has
resolution for 1200 PPI, and needs at least in the range of 300 for "flat comfort"..
So, if you scan a 6" x 4" image from an extraordinary high pro camara, the print
media resolution needed is about 439 PPI ... the Windows 96 PPI is just SHORT !
That same 6" x 4" scanned image with no truncation will only displays on a wall
size screen and you won't see details on the legal and scientific basis, basis that
the human eye focuses best at a distance of 25 cm. and under certain vertical and
horizontal angles. So, for your "wall print size" you will have to move the head
around, but the human eye has no memory , i.e: it does not have the capability
to juxtapose. If the human eye would have memory, you would see all the day
long this lovely capucino you had in the morning. Memorizing your boss face
[if you don't like particularly] is another psychoprocess, "fixation".
Photons have no color, just energy. Colors is a pure conventionalized fabrication.
These two work sheets contain notes.
L'imagerie est la deuxième science menteuse après la statistique.
Cependant, Fourier n'est pas menteur en imagerie, seulement le déluge qui en ...
jmG
What's wrong again: it does not spell check ?
Nov 11, 2010 3:28 PM UTC
I was having the same problem with 3D plots not showing up (blank display) in V14 running on 32bit Vista. I found the best and least intrusive fix was to select Compatibility tab in the shortcut properties, and then check "disable desktop composition". This way the Aero features work for everything but MathCAD, I can keep borders on in the 3D plots if I like, and I can also create more than one instance of MathCAD one with and without the "desktop composition" if I like.
Jan 17, 2011 12:16 PM UTC
I find that switching off the Aero enhancements is a very good cure for blank plots. In my case I have just reinstalled Mathcad 14 on a machine running 64 bit Windows7 and found a lot of this in other peoples workbooks - including mathcad's own e-books. Turning off Aero completly removes the problem - but I like this way of turning it off on a per application basis (although note that aero dies for everything whilst that application is running).
The problem is not, I believe, due to Mathcad but rather to problems with Direct-X. I have seen problems with totally unrelated programes that can be cured in the same way ( offset mouse pointers in Pinnacle Studio 14 video editor (2D titler) and Crysis games 2 D menus) and note that Microsoft's Flight Simulator turns off these features when running. The same problems occur with different graphics cards - I have used both ATI and Nvidia cards.
The problems can also be stopped by going to 16 bit colour settings - but this is not a good solution as it will adversely affect other programmes
Jan 17, 2011 10:21 PM UTC
Do you mind mentioning the specifics of hooks into changing the Areo enhancements under windows 7?
What you are saying makes perfect sense. In is not uncommon for some recent system add-on to tromp on existing standards. add-ons are often not thought about and systematically accounted for in the same way that a balance in a bank account is so everything doesn't always add up to what it should in terms of interacting with prior capabilities.
