3D plots - Proper x & y axis scaling
I've been trying to find a way to plot the data I have with the proper scaling of the x & y axis. The information I have is from test data, where I have calculated the gibbs energy of the test conditions. I have a set of data of particle measurements that are given in size ranges, but I'm not able to get the data properly graphed with the scaling I'm needing.
The information is in the attached file.
RichardJAnswer
Dp has one less column than Data or Gibbs. Reduce the number of columns in Data and Gibbs by 1 and the second 3D plot works.
jroth5-Regular MemberAuthor
It appears the data wasn't saved with the files, attached are the text files with the information.
RichardJ19-TanzaniteAnswer
