A question on activation energy determination
- 11 replies
- 6185 views
- Translate All
Having a group of experimental data like following
where α is conversion of the reaction under research. some important kinetic parameters like (E/R) are needed to be obtained from above data.
and the following model has to be considered,
Above function will be used to fit the experimental data in order to determine E/R and lncA from slope and interception, respectively.
And this will require that m and n have to be obtained in advance.
according to my solution, lncA, E/R, m and n have to be determined at the same time, I dont know how m and n are got at first.
data are attached
