AC induced voltages on buried pipelines.
- 8 replies
- 3353 views
- Translate All
I am struggling to show the result of the calculation in terms of the voltage and the phase angle (in degrees). Vp calculation is correct but it does not show the phase angle. The phase angle should be -121.4 degrees as shown on the sample calculation at the end of the works sheet. I can produce the correct result in Matlab using the rad2deg function ( [abs(Vp) rad2deg(angle(Vp))] ) but I cannot find an equivalent function in Mathcad. Any guidance gratefully received.
Thank you.
