3-Newcomer
Access to Mathcad 15 Files after Jan. 31.
is there a possibility to access version 15 files after end of January, i. e. with a viewer programm or evaluation license?
Regards
Holger
If your Mathcad license ends on Jan 31. then you have at least 2 options:
1) If you have a Prime license you can try to convert the files to Prime format. Be aware that depending on the functions used by Mathcad the Prime file possibly won't work OK or will need a lot of rework and clean-up. Starting from Prime 7, the converter does not need Mathcad 15 to be installed and I expect it to work independent from your Mathcad license as long as your Prime license is valid.
2) For viewing the files you can try Luc's viewer for MC14 and MC15 files: Re: Can't see your sheet, but... - PTC Community
23-Emerald V
In addition, Prime (7 and up) also allow to convert a Mathcad (15 and below) file to html format. That is, it is not converted to Prime format, but the sheet is calculated and the result is presented in a html file, showing how it would look like in Mathcad, and viewable in a browser.
