Jul 30, 2013 10:41 AM UTC
Accessing one mathcad script from another
I need your help in solving the following problem -
Say, i have a main program worksheet ( Say A.xmcd ) where i have my inputs . Now my function ( set of calculations) is in another sheet ( Say B.xmcd )..
Now i need to pass the inputs from A.xcmd to B.xcmd and receive the ouput from B to A .
Say we have a very simple program in A.xcmd
input
x= 3
Function
f=cube (x)
B.xcmd
x1=x
value = x1*x1*x1
return(value)
The above stated are not exactly the syntax but a pseudo code .
How do i link A nd B from A ???
Jul 30, 2013 11:02 AM UTC
You would have to use "Insert"/"Reference" to achieve what you want.
While it is possible that A references B and also B references A, I wouldn't recommend it. If you use just the function cube() in the attached sheet B, then there would be no need that B references A.
So I would suggest to avoid circular references and that you put your calculations written as functions (like cube()) in sheet B and reference it at the top of sheet A, which takes the input values and uses the functions written in sheet B.
See if the attached would help - it still uses the circular reference which works, because of the very simple mechanism: whenever you insert a reference is is as if you would type the whole content of the referenced file in that position. So see yourself, insert the reference to B in sheet A a second time and look what the value of x is. The function cube() will be defined two times that way which does no harm.
Jul 30, 2013 1:23 PM UTC
Hey Werner ...
THanks..its working...
