Adjust Bessel function to data
I need to adjust a Bessel function to this data. I was unable to make it and I can't discover the error. Can someone help me?
LucMeekesAnswer
23-Emerald V
The Bessel function will not work, note that J0 does not have a flat lower bound, like your data shows.
It may help to square the Bessel function, like this:
Which error?
Post your Mathcad or Prime sheet!
M_U1-VisitorAuthor
I'm trying to use the QuickSheet of Fitting nonlinear functions to data. But my problem starts when I have to define the bessel function J0. I don't have the analytic expression for the function, so I can't use the genfit.
The Bessel function J0 does not have any parameters you may twist to fit to some data.
Why do you think that you must fit with a Bessel and what modified version of Bessel do you have in mind?
Where does the problem stem from?
LucMeekes23-Emerald VAnswer
23-Emerald V
