Apr 29, 2011 6:25 PM UTC
Aligning Regions Vertically in Prime
I am trying Prrime for the first time today.
How do you align regions vertically? I know how to do it in M15, but I can not figure out how to do it in Prime. I also can not find in the help guide.
Andrew
Apr 29, 2011 8:14 PM UTC
Acording to the migration user's guide (under the getting started tab), region alignment feature is not included in Prime1.0. The regions snap to the grid so you can use that instead.
You'll find the help guide under the getting started tab also.
I hope this helps.
Norm
May 1, 2011 9:01 AM UTC
The above post is correct.
You can also change the grid size which makes it easier to align.
Mike
May 13, 2026 5:08 PM UTC
Freaking unbelievable!!  I am being FORCED to finally switch to Prime as Mathcad 15 can no longer be installed on new computers.  I never switched because I was always waiting for Prime to catch up.  Well, 11 years later, Prime 12 has still managed not to catch up on even the most simple and useful capabilities.  PTC has ruined this previously fantastic software.
