ttokoro
All distances of the points to be Integer
(This is only a puzzle to fun! )
Tokoro.
  1. Make a circle with its center (0,0) and radius r.
  2. Make five points on the circle with all distances of the points to be integer.
  3. The puzzle is to find the minimum of r.
  4. Next, the same puzzle except the number of points are 10.
  5. The answer of 4 points attached.
terryhendicott
I found the lengths 4,6,4,6,4 by trial and error until I got integer results for the diagonals.
Regards
Terry
terryhendicott
I'll play  (The definition does not need the radius be an integer?)
23-Emerald V
You are not free on the radius. Because the diagonals are twice the radius. Hence radius must be an integer times 1/2.
Which diagonal of which pentagram must be a diameter of the circle? There may be a solution where one diagonal or maybe even one side of the pentagon is a diameter but sure not necessarily.
Even with four points its not demanded to be a regular quadrilateral or to have any symmetries. Its just the solution shown which happens to be at least a rectangle. And I see no proof that 5/2 is the minimum for the radius in case of a quadrilateral.
I have no clue how to proof that the solution for 4 points shown really is the minimum (wrt the radius) and that not maybe an irregular quadrilateral would not lead to a smaller radius.
Nor have I any idea how to use Mathcad to help finding any solution with 5 points, let alone the minimum one.
Its clear that it suffices to demand for all distances to be rational as we then can blow up the figure as necessary to make them integer, but I don't think that knowing this is much of help.
ttokoro
ttokoro21-Topaz IAuthor
t.t.
ttokoro
t.t.
ttokoro
t.t.
ttokoro
This answer of n=8 is r=
‎It is very large and the shape is not smart. So, the best answer should be more small.‎‎
t.t.
ttokoro
Mathcad Prime 6.0 sheet. n=8
n=9
t.t.
ttokoro
ttokoro
ttokoro
ttokoro
t.t.
ttokoro
t.t.
ttokoro
Find the new 4 points answer.
t.t.
ttokoro
Answers of n=4 to 13. No.5 is find by terryhendicott.
t.t.
ttokoro
New stab series (red line) reduces to only 7% at 50 points.
(3663075,0) (-3663075,0)
(3649821,311328) (-3649821,311328) (-3649821,-311328) (3649821,-311328)
(341859,3647088) (-341859,3647088) (-341859,-3647088) (341859,-3647088)
(3596925,693000) (-3596925,693000) (-3596925,-693000) (3596925,-693000)
(723075,3591000) (-723075,3591000) (-723075,-3591000) (723075,-3591000)
(1025661,3516552) (-1025661,3516552) (-1025661,-3516552) (1025661,-3516552)
(3491709,1107288) (-3491709,1107288) (-3491709,-1107288) (3491709,-1107288)
(1672419,3259008) (-1672419,3259008) (-1672419,-3259008) (1672419,-3259008)
(3244899,1699632) (-3244899,1699632) (-3244899,-1699632) (3244899,-1699632)
(3219171,1747872) (-3219171,1747872) (-3219171,-1747872) (3219171,-1747872)
(1774749,3204432) (-1774749,3204432) (-1774749,-3204432) (1774749,-3204432)
(2040675,3042000) (-2040675,3042000) (-2040675,-3042000) (2040675,-3042000)
(2348931,2810808) (-2348931,2810808) (-2348931,-2810808) (2348931,-2810808)
By H. Fujiwara.
t.t.
ttokoro
t.t.
